tman7
I Was considering purchasing a pumpout for my Boxxer 421 and ran accross this article http://www.simplysteaming.com/simply-st ... m#Comments for an APO using a Shurflo pump. I personaly talked to the guy and he says he has had no issues with it, works great. Definitely a huge difference in cost if your the DIY'er type. $500 vs $1700 http://interlinksupply.com/index.html?i ... PHY079-091 for the Dura-flo, but I did notice he is using a manual ball valve as a backflow/check valve. Kind of takes the A out of APO, IMO. Would a valve such as this http://www.homedepot.com/webapp/wcs/sto ... 5f13736960 work to prevent a leak when the pump isnt running or would it get easily clogged?
Any comments on the feasability of the project in general would be appreciated.
Thanks
Thanks
