gimmeagig
I'm really frustrated. Shortly after I bought my used Ram Van with a Hydramaster CDS 4.8, it developed this annoying squeak. I took it into a repair shop and they changed the belt. It was better but eventually it came back. I've lived with this fan belt squeak for a long time now but 3 days ago I decided to take it to a different place to have it fixed.
The mechanic checked it out and suggested a new fan belt tensioner and a new fanbelt.
I had him install that and it was fine for a couple of days. This morning it started squeaking again.First only at higher RPMs.
I took the truck back in and the mechanic told me that the belt could maybe use a little more tension. According to him the belt that was installed was the shortest one available( It's number was the written in the inside of the engine compartment, probably by Hydramaster).Someone suggested a Gatorback belt when I originally posted a question about the squeak a few years back.But the Gatorback is no longer made so that is not an option anymore.
My mechanic told me he could fabricate a bracket for the alternator mounting, that would make it possible to increase the belt tension a bit more.
He also sprayed some belt dressing onto the fan belt. That made it worse.The mechanic suggested to drive it for a while to see if the squeak would go away. I have driven it all afternoon but it seems to be getting worse.
I don't know if putting more tension onto the belt wouldn't put more stress on the bearings but I don't have any other ideas.
Has anyone else here had this problem?I could really use some help.
Thanks
Thanks
