jstucky
- Joined
- Sep 12, 2008
- Messages
- 451
- Name
- Jordan Stucky
Yes I'm a hack, I have TWO porty's. Both with water dripping underneath.
Ok...So I think we can eliminate the obvious problem on one porty of the pump going bad..the pump is only a couple weeks old.
Pump on my main porty started fluctuating pressure and started dripping last week. Ordered kits to rebuild. While waiting on the kits I pull out back up porty. Only 150 psi machine that I mainly use on upholstery. Just REPLACED pump on it a couple weeks back. Has worked great since.
My EVO wand has been dripping for about a month. Just a drop or two from the valve when starting up then it is fine. I have been using my Reg. SS Wand with my back up the last few days. I decide to use the EVO wand with my back up today and it started dripping water underneath the machine. But with SS wand, no dripping water.
It seems like it takes a few times to prime main unit to be full pressure. Do I have a problem in the wand? I took out the inline filter a couple years back and unless the valve has one in it, I don't think it has one. Do I have a problem in solution hoses? Or QC's?? I replaced a male QC on main solution hose and that helped a little bit. The seal was broke on the QC and it was spitting a little when un-hooked from the machine.
What is if any maintenance on solution hoses?? Do they need to be flushed out with vinegar or blown out with air compressor??
Keep in mind with all this that I use ALOT of encapsulating rinses or mainly Judson 02 Rinse otherwise
Pump on main machine lasted about 2 years and we did valve and seal kit. Went great for about a year and now pressure fluctuating. So ordered valve kit again and piston kit.
Is rebuilding porty pumps a lost cause?? Do they ever perform like new again? Or should we just suck it up and buy a new pump every few years??
Thanks all!!
Jordan
Thanks all!!
Jordan
