Dry Foam upholstery cleaning
Can you "out" him, so he can tell us why? And how is his process being performed?
No, up to him..
Its unfortunate that he feels like he can't post his questions and comments directlyI've learned that there isn't that "Olde Steam Religion" bias against other methods when it comes to upholstery cleaning that surely exists in carpet cleaning.
Even Mr Ladwig sees that there is sometimes safety and wisdom in cleaning upholstery with a low moisture system.
In any event, what I think some of this comes down to is this:
1. Is the choice to use dry foam as a cleaning method being done because its the safest method, or just to save time?
2. Is the method in question one that uses the "mountain of suds and a sponge" technique, with just wet vacuuming as a follow up, or is it a mist and towel extraction technique? Both save time, but the first does leave a great deal more residue on the fabric.
This has been, and can continue to be a good conversation here.
One last thought: Given the choice between leaving too much shampoo residue on a fabric, or leaving it saturated with oily dry cleaning solvent, I'll take the shampoo residue. There is far more risk of skin (and respiratory) irritation with the solvent than the shampoo.
I actually think it takes us longer. :errf:
A better pre-vacuum, hand work with whipping foam takes along. (a foamer, pump-up would be faster). Post wipe down with terry towels. I feel HWE is much faster and hate to slow down to hand work unless absolutely necessary. Such as safer due to using less moisture with that method.
So I take it no pixie polymers were ever introduced to these Foamers?
I can't speak to that Mike.
I can say that I am impressed with how well the encap products I tested on upholstery worked. But I also worked hard to remove the residue, as there is no benefit that I can see from having them remain on upholstery textiles.
The gentleman in question was excited about ease of use, time saved and yes, outcome.
But just like carpet rinses and de'limoline based presprays, you never really know the out come for a year or more when loads of 2nd visits start happening
Reactions: Mark Saiger
I like seeing people trying to improve their craft. Ask if he's tested protector after his cleaning method, if protector is important to him; it might not be after all.
amazingly I've never been to the VS website.
I could just see Ladwig buying into this cult.
In fact I think that's him at 3:45
Roberto is Nebraskan for "Alien Freak"
CCA will bring this Foamer unit to both Atlanta and Nashville for us to clean Kellie and Meg's bufonts with..
xVQJu2rP9Q8RKkaZygDFBtX7ZXDAgua91-u4HQORXwOR9ijRAQBlJJaO2CifEBP_3aBQ4WdhdqRfY3-ykg=w1327-h996-no.jpg
Reactions: Mark Saiger and CCA
Danny Strickland
I just sold my VS Esprit and prior to the sale i cleaned my micro fiber "love couch" with a well forulated encap product. It looked as good as any HWE i've done and it still looks good a few months later!
the Mystery Foamer is not commenting out of fear of the many lurkers in his areas, not out of embarrassment.
Then he should go back to foamers corner. What's to be afraid of? We've got hacks of every kind here. Right Porky?
Shorty
Shorty Glanville
Great post.
Great post.
Jim, depending on the products used, what problems do YOU foresee with encap products remaining in the upholstery.
Most will be aware of the young & very old or those with respiratory problems, but anything else that others may not be aware of??
Thanks,
:yoda:
Unless someone has sensitive skin, probably nothing serious. I will add that I am not convinced even now that dry vacuuming alone removes as much encap residue and soil during the "morning after" dry vacuum extraction technique on carpet.
In upholstery cleaning though, most cleaners are using towel extraction, often with an orbital buffer. This system removes a great deal of residue and leaves fabrics soft and bright. Other than a few hypersensitive white natural fibers that could brown out or very unstable dyes that could bleed, encap products can replace shampoo in most cases.
Shorty
Shorty Glanville
I also am of the opinion that the action of sitting on a sofa, etc; is enough to expel a fair bit of the encap; residue from the furniture.
Thanks Jim.
I wouldn't worry about the encap residue if you use an orbital buffer afterward. Even wet vacuuming will remove some of it. If you think of it, we do neither for the most part after we apply and agitate encap products to carpet.
With towel extraction, you leave less "stuff" in the fabric than you would with conventional dry foam processes.
Reactions: Shorty
Enge
We've gotten very good results with our VS system.
The last upholstery I entirely cleaned with foam was very early 80's.
As Jim noted, mixed results and sometimes noticeable residue. It's still useful.
Easy on overuse of sodium laurel sulphate though.
Sodium laurel sulphate is the common ingredient in most shampoo products. Since its usually used as a shower feed or "sponge dipped in foam" technique, I can't speak to how they might affect you when sprayed.
I encap our office and a friends place of business and never have any negative reaction to what I spray when I do it.
But, to be fair, I grew up in a dry cleaning plant breathing perchlorethelyne, and used to custom mix the cleaning agents for our cleaning company with 2-butoxyethanol and sodium metasilicate.
Most anything is mild compared to that.
Marty, are you using Ricks tea oil based encap.
There are many that do not contain it, he does too. And surround has a fragrance free one.
I use their green encap and I don't get any gag reaction. And I hate most perfumes, even if they call them scents or even more "deceitfully"- fragrances :winky:
If you prefer a fragrance free one try Surround's. Never used them as I hardly use encap products (still trying to get done with existing inventory, unfortunately I am a secret chemical hoarder) . However, I've heard that they are very good.
Unless, of course, Ricky G. finally gets off his damn wagon (I like Rick and I think he runs a top notch business) and makes a fragrance free one. Mr. G?
