dry lies..
Greg Cole
Kennesaw GA
Greg
I'm shocked, shocked! :biggrin:
Yep- Couple months of work and a nice payday...... 100% cash deal. ( Took Steve Toburens advice).
Ironically it was my post on this site that prompted the phone call. Thanks Mikey! (and no you don't get a commission) :biggrin:
You didn't really think I wanted to stay in the carpet cleaning business did you? lol
Shane Deubell
Dam, wish i could do that.
One of our accounts this guy flips bars/nightclubs.
The funniest part is 3/4 times they fail and he ends up buying them back at 10-20% then flips it again. Nice racket this character has....
Seem to be around $150k a pop
He ALMOST talked me into it, until i seen the failure rate and woke the hell up.
DAMN IT GUYS! and here I've been shooting for that "Wet for days" goal like SS !
Marty can claim those 2-3 hour dry times when all they have down south are ..............dirt floors.
Reactions: Mikey P and hogjowl
GeneMiller
Boca Raton
gene miller
I was curious about actually dry with a meter so I brought one in. I had fans running for 45 minutes when I used the meter. It read 0 on the surface but when pressed in it beeped steady. We did a heavy pretreat and then scrubbed with the Whittaker. It always takes a lot to flush her carpets. She never vacuums and they track in black dirt. The large zipper has 05's I think and we cleaned it at 600 psi. It's not Saiger quality but I did video it if your interested.
Gene
Hawaii
Gene
You're running 30flow? Video please....
Reactions: Mark Saiger
Doug Cox
Delavan, WI
Doug Cox
I'm guessing we don't hear about the failure rate. I'll stick with what I do and maybe I'll stay married unlike Cole.
GeneMiller
Boca Raton
gene miller
Pretty sure that's what's under there. I've never looked to make sure that's what Eric installed. He said he wasn't sure if he had the 05's in stock but would use them if possible. Your not getting more than 3 gallons through 1/4" but it should be larger drops. It would only be 30 flow at 5000 psi with a pump and hose that could support it. I'll upload it to YouTube.
Gene
Erik
Michigan
Erik
Gene, When you ordered your Zipper Wand, we were talking about building yours with an 18 flow. However, I didn't have the 03's in stock at the time. You are running a 12 flow (02's) . With your gauge set at 500 psi, your unit is putting down 2 gallons per minute. The only person I know that runs a 30 flow is Ron Lippold. A 30 flow with a stock 3/16" line was not possible to adequately keep up the pressure at the jets. I did a bucket test with an open 3/16" and the gauge set to 500 psi. It was only able to produce 3 gallons per minute. I had Ron send his handle back to me, I thought I would have to modify it to accommodate the CTX 90 fitting. However, I didn't need to. I have a 1/4" line and the CTX fittings in stock if anyone would like to run a crazy flow like that, but I honestly don't think it's needed.
Jim Morrison
Canada
jim
I've found the only way to really find out whats going on under the surface is to run a moisture meter over the carpet. I was surprised a few times with loop style the following morning, particularly where the wand strokes overlapped!
Jim Morrison
Canada
jim
It was fun watching the Flames beat Vancouver. Our local Junior A team made it to the 3rd round of the playoffs which was the furthest they have ever gone! I'm not a huge hockey fan but did enjoy it a lot this year. Having fun with the Cleanco, will start a new thread.
GeneMiller
Boca Raton
gene miller
Thanks Eric I never looked. 3 gallons is the limit for the 1/4 " solution. You can't change that no matter what. I thought it was 05 and I got 04's but the 02's clean like mad. Now I will go and look.
Gene
Erik
Michigan
Erik
Gene, the line on your Zipper is 3/16". It can be changed out to 1/4".
GeneMiller
Boca Raton
gene miller
I looked at my jets today and Eric was right I have 02's on the zipper. I could of sworn I had 4's or 5's. Don't really care it cleans beautifully.
Gene
GeneMiller
Boca Raton
gene miller
I dint see any reason to up the flow above what you normal run on your wands..
I have 04's on my quad for quick flushing. You have to dig it out now if you want it. I won't stop carrying it because occasionally I hit a deep sculpted rug.
Gene
Big Jim
El Dorado Hills California
James Milne
We've heard it all over the years here..
Dry when I leave..
Dry enough to post vacuum..
Drier then when I arrived..
Dry in two hours or we pay your mortgage off..
What is your "When will it dry" speach..
Here's how we answer on our website. Yes Mikey tired of all the B.S. drying claims
How long does it take the carpet to dry?
Here's the truth about how long it takes carpet to dry; it depends. There are many variables that determine how long it will take a carpet to dry completely. They include; weather conditions, air flow, type of carpet, carpet protector application, and level soiling just to name a few. We specialize in structural drying and understand the difficultly in predicting dry times. We also realize dry time is important to customers, but will not contribute to unrealistic drying expectations. Carpets may feel or appear to be "relatively" dry shortly after being cleaned but may take a number of hours (not days) to dry completely.
