Monzie
CARPET CLEANERS - NEED YOUR INPUT! Just shy of 3 years ago I bought a DYNACHEM DC-534 Truck Mount. It has been a great w/no issues until about a week ago when it burned up the crankshaft seal. The mechanic noted uneven wear of the crankshaft bearing. He says was caused by a design flaw- the belts are much too tight, with no tension adjustment or idler pulley to adjust them. As a result the torque created resulted in bearing failure. I will need to buy a new engine on a unit with less than 1200 hours. If ANYONE ELSE owns a DC-534 and has had similar problems, PLEASE CONTACT ME! Thank YOU!
