CanadianRuss
- Joined
- Jul 27, 2015
- Messages
- 265
- Name
- Russ Teskey
Who uses emulsifiers and why?
Sorry I meant some cleaners just use an emulsifier with there rinse. Especially with upholstery. To me I would prefer to use a pre spray with an acid rinse.not sure what you mean..
are you wanting to use a rinse through your TM that leaves a polymer behind?
I messed that post up real bad. Hey it happensnot sure what you mean..
Can you chime in now.I don't use encapsulating presprays while doing HWE, so I can't say from experience.
If fact, I don't even know why I am responding to this.
Carry on ...
Russ, this has been a subject of discussion on MB since its inception. A kind (an more qualified) soul will like give you links or show you how to do a search.
I will answer to the question when it comes to upholstery cleaning here though:
Upholstery fabrics are thin, relative to carpet, and can often be thoroughly preconditioned to the point where its not necessary to use an emulsifier in the "rinse/extraction" part of the cleaning process. Using soft water as a rinse can be a very good alternative, or you can use an acidic rinse agent if you need to:
1. Neutralize your preconditioner, should it be alkaline in nature.
2. Stabilize dyes, assuming that you have tested the dyes and know that an acid will stabilize them. (Not all dyes are stabilized by acids, and some bleed to acids, though that is a rare occurrence.)
3. Soften fabrics. Pile fabrics, such as velvet and chenille, tend to dry softer when rinsed with an acid rinse, though soft water also has been shown to assist in this case.
4. Restrict browning. "Restrict" is my weasel word of choice that I use instead of "prevent". Some fabrics will still experience browning, even when rinsed with an acid, if you allow them to take too long to dry.
Because of the above benefits, I use an acid rinse when I clean for "friends and family" or the odd antique or museum piece people ask me to see if I can restore. (Come to think of it, my daughters think I'm an odd antique or museum piece).
I hope this helps.
Trying take up the slack on DAP's? Honorable to attempt it but lame result. You come of looking really stoopie.I don't use encapsulating presprays while doing HWE, so I can't say from experience.
Carry on ...
Where does the encapsulation part come into his answer?
Fortunately, it's not what you think that counts.I think it depends upon what we are cleaning. Light to moderately soiled All Fiber rinse works really well.
However if it's more than moderately soiled I think it takes more punch to be efficient with production time and effectively deliver the desired results.
What ever I tell them to.Fortunately, it's not what you think that counts.
What do Dan and your crew chiefs think?
On January 13th Scott Warrington will be on MBWebinars to discuss acid, soft, RO, tap, encap and alkaline rinses.
