Etched stainless steel
CleanEvo
I got some overspray on a stainless steel stove. I used Prochems high PH tile & grout cleaner. any ideas for cleaning this off? Or did I just purchase a new, slightly blemished, stainless steel stove?
Ron Lippold
it happens I have used wd40 and it works as good as anything.
CleanEvo
Thanks Ron, I'll give that a try.
Someone on the ICS board suggested Brasso as well... I'll bring both.
Cheers
boazcan
Go to auto parts store.
Look for any decent metal polish (aluminum, ss type) mostly used on tire trims. Buff it out after finished with wd 40.
That was the one and only time for me. I only use a mop and bucket to apply any solution to a tile floor. I also wrap stainless steel just in case, plus the custys like it too.
It should come off unless it is a faux cover.
safeclean
Try using an organic acid next time than you will not have to worry about stainless steel as it will clean that too.
Craig
Gary T
Barkeeper's Friend. Works the best. Remember to polish with the grain with any of the solutions offered or you will get swirl marks.
