Female quick connect at machine keeps leaking
Josh Almanza
Josh Almanza
Changed out my hoses and installed new male on my wand since my hoses were getting harder to put on(even with no pressure on hoses) now my female at my solution pump continues to leak. Is this an indication there are issues with my pump...or just needs a new female fitting? Thanks.
you mean the fitting at front of TM?
and not a fitting ON the pump behind the front panel ??
if the QD (quick disconnect) is leaking at the front of TM, replace w/new
.....they don't last forever
Josh Almanza
Josh Almanza
Female at the front of my pump where I connect my solution hose to my truckmount
O ring worn out, replace the fitting. The hottest water passes through there and wears it out over time. Replace the pump when you have pressure problems and rebuild is no longer an option.
Metal fatigue.
Replace everything or do it one at a time.
Everythi g you put a wrench on or torque on should be replaced or it too will leak in a few days.
Metal fatigue.
It that like when everything Midas touches turns to gold? 🤔
Shane T
Shane Tiegs
If the female quick connect leaks without a male fitting inserted replace it, nothing else will fix it. If it leaks with the male fitting inserted replace the o-ring or rings in the female.
Interesting how some call them qc's (quick connects) and others call them qd's (quick disconnects)
It's all relative
If anxious to get started, it's a QC
If anxious to be compete and wrapped up, it's a QD
(guess which one I am)
it's same, only different
.L.T.A.
Bob Savage
Bob Savage
Do you run hot water through your pump?
Most TM's run cold water from the pump through the heating system first, and then from the heating system to the front of the TM panel where you connect your hose that goes inside.
Josh Almanza
Josh Almanza
Damon on Steveo's putter??
English isn't your first language is it.....
reemplazar la
Most TM's run cold water from the pump through the heating system first, and then from the heating system to the front of the TM panel where you connect your hose that goes inside.[/QUOTE it’s a Prochem legend gt model 2017
jack zerkie
I use the white magic set up and my males leak just like me. But with a shut off on the male I always blead the line on the first job each day to flush anything left from the day before. And with the male if it's open just a little you can relieve the water pressure. jz.
