if you look back a couple months you can find my post about it. IMO its a niche prespray, don't go into your average house thinking its going to blow away a regular prespray like say ultra pak traffic clean. its not in fact while I haven't tried it the couple people that I have talked to that were disappointed with it tried it in the above scenario I described. again I haven't tried it in a home but I suspect in your average house its NOT going to work as well as a standard prespray like ultra pak for example. HOWEVER if you have a nasty olefin glue down in a wharehouse it kicks total ass, especially when coupled with some heat from your machine if you machine is producing oh say 200 ATM and higher in this application I will call the results stunning over anything else I have used. the product is designed to break up oils which is exactly your main issue with olefins. now that I think about it, it might be worth a try on some nasty polyesters in homes.
so yeah IMO its a breakthrough product when used as its designed and in the application it was designed for. which is saying alot because alot of stuff claims the same thing but doesn't really deliver. interlink sells the crap out of the stuff so it must be working for others too.
