Mike Draper said:I think the most accurate way to get a reading at the fiber would be to get 2 identical wands with different flows.
egg-zaccally
Get the water coming out hot. Then without the vac hose hooked up, key back and forth strokes across a room while someone is taking readings with a thermal imaging system.
I'm not so sure those thermo temp readings would be so accurate, Drapes
(for the application of measuring jet spray ATF)
I saw someone trying to use one before to measure spray temps...it didn't work so well and readings varied all over the place
I believe this would give you the most accurate reading possible of "At the fiber temperatures". You would especially be able to see and read the temp differences with different flows. there may be no heat difference between a 12 flow and a 20? Who knows until this is tried?
we disagree, cause I don't think you can much more accurate than actually putting a temp probe directly under the jet stream
Those thermo guns aren't that expensive anymore.
sacrifice one outing with your AR and what you save in ammo will buy you one. :mrgreen:
Joe, yes I "had" an ATW temp device once.
I built it myself a few years ago.
and used it a couple times til the thermometer stem and thermo head BLEW out of the holder and smashed against an apt wall... :shock:
Guess I didn't make it as well as I thought I did....
anyway, I agree it's much easier to read temps with a wand lie detector....however, where the spray hits the fiber is where the rubber meets the road.
as you mentioned and know, wand designs..in particular jet to fiber length has a HUGE impact on heat to the fiber .
The ATF temp tests I did years ago are skewed due all the parameters not being the same.
IE..different ambient air temps, and longer sol line runs and 100 psi less...but with a 2 jet 06 flow wand, the best I could get ATF was 146.
An identical 04 jetted wand showed an anemic 120 (if I recall right)
with a stock Ti 06 flow, I recorded a top temp ATF of 180
Our Ti wand now if flowing 2gpm @450psi (bucket test) and has long jet extenders .
unfortunately, the one time I decided to measure temps, the battery was dEd in the thermometer.
Been too lazy, or never think to buy another one when at the places that sell them.
So I've done no temp tests on the extended jets and increased flow.
Maybe I'll get on the stick and remember to do that soon
Lumber Jack, I'm a believer in the shear angle effect.
However, on a wand with out wings, the fly in ointment "I'm" finding is getting them to work well at 450-550+ psi without splashing all over the place .
I wonder if the additional steam you're seeing isn't due (at least in part) to the jet spray "ricochet" effect ?
