- Joined
- Oct 22, 2012
- Messages
- 28,230
- Name
- Ron Marriott
Yeah but you'll hump anything.I am amazed with the 370. A few more adjustments and ill be humping the entire setup.
Legend Brands" data-source="post: 4718756" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">We have a video on how to adjust the incoming regulator, how to clean the filter inside the incoming regulator as well as some other basic maintenance items on our YouTube channel.
My cell is in my signature. You could have called me.@Mikey P I guess there will be a delay in the Humping.
Do the circuit breakers have glass fuses in them or If tripped- need to replace the whole circuit breaker.- All but temp breaker (4 total) Tripped.
Please direct me to an instructional video.
Thank you.
Apparently this unit''s instrument panel was damaged during shipping. A new one was installed but the Hour clock wasn't wired.
I located a loose unattached wire on the panel and connected it to the clock--Well THAT was a mistake- it trpped the 4 breackers and now I dont have water pressure-- The cat pump clutch isn't engaging.-- yes i turned on the switch and water was flowing into the TM.
The tech at the dealer tells me to bring it IN-- but I'm very busy.
I'm one guy with Two machines-- and I wouldn't have it any other way--Cuz it gives me peace of mind.
Legend Brands" data-source="post: 4719402" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">My cell is in my signature. You could have called me.
The breakers do not have fuses. You can just push the breakers in to reset them. They are like house breakers, the more they trip, the weaker they get.
Did you get it fixed?
