rwcarpet
Not synthetic, what weight are you using, 'specially the 4 cyl owners? I'm still using 30 wt Pennsoil because my engine never gets cold. It stays in a heated garage when not in use. Ford recommends 30 wt if above 40*, or a 10-40 if under that temp. Now, are they talking about the engine temp as it sits, or the temp that it is "breathing" in while running in sub-freezing temps??
