? for V owners
Luis Gomez
Luis Gomez
Is this worth 50K or will I be buying a big headache?
2004 UD nissan (32,765 miles)
+ aluminum skid plate flooring
+ Interior lights
2004 6008 (2100 hrs)
+ 220 gal SS fresh water tank
+ upgraded pneumatic blower
+ backup calibrated md blower
+ exhaust heat transfer system upgraded to heavy duty
Thank You all for your response.
Luis
AshleyMckendree
Ashley Mckendree
For that money you could get two BRAND NEW Judson C4's and a box truck.
rcl1006
i think it`s alot. you can get newer equipment for a better deal.
too much.
Get used box truck (one that is serviced LOCALLY) and put two slide in machines for the same $
Brian R
Brian Robison
Get two vans and two TMs
Why have a Siamese rig?
If they aren't conjoined, you can do so much more.
good year for UD..6008 are the best out there.........
but it is to much and has been altered...
can someone explain..............
AshleyMckendree
Ashley Mckendree
Im guessing there xtherm system was removed and a regular exhaust exchanger with a diverter was installed?
Luis Gomez
Luis Gomez
I was going to offer 40 K, and it does not matter what I buy. It will be between 40 and 50 k.
Judson C-4 18 k (plus shipping and install), El diablo 18K ( no shipping because I can drive to interlink) and Organic Compounds has a 8500 with a 1500 nissan engine, 200ft of hoses and reel for 17K (600 hrs). Add the price of the van or box truck another 25K. Plus extras; more hoses, chemical shelves, stair tool and all the other stuff we like to have in our trucks.
So I guess it is a matter of preference. I was worried about getting service and parts for the V.
Luis
Parts are easy..you just have to look for them.there is nothing on these trucks that can't be fixed or replaced...........as far as service........there is a hand full of us on the board that can trouble shoot most of them out there...if you can turn a wrench then you should be able to get it running....I am only talking about the machine....the UD is another story......in most cases it is better to take it in to get it repaired at a local diesel shop.........there are a small hand full of things on the truck that can be figured out that are tied into the machine ..But take note....the diesel engine in this truck is made to run...and if it was taken care of you will get years of service from it.....but sooner or later everything breaks down and parts for the UD are spendy............
If you offer 35-40 it should be a good deal for you, if the truck is in good mechanical condition. Also make sure the box truck setup is what you are looking for as it is not for everyone.
Also you need to find out what you are going to do with all your extra time you are going to have after working faster with the v everyday.
