I have 20 two gallon "cases" of this new Clean Freak Encapsulation Cleaner to GIVE AWAY (at no charge) here to you Supportive Members.
Enter the raffle to the LEFT of YOUR screen -------------------------------------------->>>>>>>>>>>>>>>>>>>>>>>>
CleanFreak® Carpet Encapsulation Cleaner
(2 gallons per case)
· pH: 6.0 - 8.0
· Scent: Orange Citrus
Regular Price: $32.16
Sale Price: $24.74
Click here for a copy of the Carpet Encapsulation Cleaner MSDS sheet.
With the CleanFreak Carpet Encapsulation Cleaner, you get an interim cleaner that not only effectively cleans all types of carpeting, but it also continues to clean your carpeting every time you vacuum. The encapsulation technology effectively surrounds dirt and soils to eliminate their"stickiness" and allow them to be vacuumed up, instead of staying attached to the carpet fibers and attracting other dirt.
Simply pre-mix the correct amount, and pre-spray your intended cleaning area with one of our pump up sprayers (it is best to start in small, sectioned areas). Then scrub with one of our rotary floor buffers, and several carpet bonnets. Then simply allow the area to dry, and routinely vacuum. The greatest part of this process, is that no additional work is needed after the initial cleaning The commercial institutions, should already have a routine vacuuming schedule set that will continue to clean the carpet over time.
Safe for use on wool carpets, upholstery, stain resistant and standard carpets. This process should be used only as interim commercial cleaning tool, and not as replacement to full carpet extraction. A full extraction of the carpet should occur after every 2 -3 encapsulation cleanings.
For a more comprehensive selection of our carpet cleaning chemicals, please check out our full lines of extractor carpet shampoos and bonnet scrubbing chemicals.
Directions:
1.) Thoroughly vacuum carpeted areas that need to be cleaned.
2.) Dilute product at 4 ounces per gallon of water for mildly soiled areas, and at 6 ounces per gallon of water for heavily soiled areas, as well as traffic lanes.
3.) Pre-spray desired cleaning area and let solution dwell for 5 to 10 minutes. It is best to work in manageable sections, like a 10' x 10' area.
4.) Soak a carpet bonnet in the solution and then wring out and attach to the pad driver of a floor buffer.
5.) Follow our bonnet scrubbing instructions and scrub this same sectioned off area with a carpet bonnet to break apart soil bonds.
6.) When carpet bonnet becomes overly saturated with dirt, flip over and use the other side, if it is a 2 sided bonnet, or switch out for a new one. Go back to step 4 and repeat until entire area has been scrubbed.
7.) Allow area to thoroughly dry.
8.) Routinely vacuum to recover encapsulated dirt.
Order Online or Call 1.888.722.5508 | Ordering Information: | |||||
Product Information: |
· pH: 6.0 - 8.0
Sale Price: $24.74
Directions:
Specifications: | |
Recommended Protection: | Goggles & gloves |
Dilution Rate: | 4 ounces per gallon of water |
Solubility in Water: | Complete |
Specific Gravity: | 1.01 |
Scent: | Orange Citrus |
Color: | Light amber |
pH: | 6.0 - 8.0 |
Case Size: | 2 gallons |
