I soo disappointed in you pigpoop, your one chance to rise above the slop and you can't see it. Are you blind too? Must be the name no matter how it's spelled.
Just an emulsifier, no prespray did this. Double wet pass, double dry. For those NOT using an emulsifier in your rinse:
A) - What aren't you getting out?
OR
B) - Why are you working so hard?
Hold the canard about "residue", at an ounce or so per 5 gallons RTU, with an 80% or better recovery rate, that's a red herring.
what are you leaving behind
rub a white towel on it to see for yourself
That, indeed. Big Z is the actual colour of the carpet. No prespray, 2 wet 2 dry, 350 PSI probably around 180 or so.Ninja Worrier 500, dual 3 stage, Kleenrite Heatrite 2 , modified from 190 thermostats to 2 sets of 220, 50 feet 1 1/2 inch hose,fixed grey cuffs, Goodyear Neptune, 15 to the heater, 35 to the wand, Parker fittings, male to machine, terminal female,ball valve, AW29, soft touch valve,2 1101.5's, Greenglide hybrid. Did I miss any details?
No kidding!
Next time just say it's:
Sorry, don't hate me Willy!![]()
