Mike J
- Joined
- Feb 21, 2022
- Messages
- 1,326
- Name
- Mike Joannides
I have an 8 foot garage door opening. Do these newer style square looking vans fit? (big enough for slide in truckmount)
No.....Crash hatta put a new door beamI have an 8 foot garage door opening. Do these newer style square looking vans fit? (big enough for slide in truckmount)
Oh @Mikey P coming to visit?I'm building a 32x48 right now.
Went with 10' doors and a 10k. lb. lift.
Should handle anything I need in the future.
You need more speed.First thing I can't find the answer for on Mikeys Board on how to get a 8 and 1/2 foot truck under a 8 foot door. lol
RV antifreeze ate up the metal in my water box. I had better results with low temp windshield washer fluid.Figured it out. Now I get whatever I need but no garage option. So now with the RV Antifreeze, I have to winterize, not a big deal. The PTO is the van of choice for me in the slow cold days of winter. So the board nailed this one for me again. Im getting a Slide In next.
I will look into that. good to knowRV antifreeze ate up the metal in my water box. I had better results with low temp windshield washer fluid.
My low roof transit doesn't fit. The door hangs just a few inches too low.my low roof passenger Transit fits
I wonder If the door height could be adjusted.
Thanks Papa John, its not an issue now because it makes sense to keep my 2016 inside, especially winter, and the new Truck will be in driveway with no limits. I just got a new door opener. No track it just mounts to the side of the bar on the wall. thing is sweet.My low roof transit doesn't fit. The door hangs just a few inches too low.
The roof inside is higher, but the opener hardware hangs too low.
Best to measure the height @Mike J to be sure as your results might vary.
Interesting. Can we see it.
This particular door is a little heavy for regular lifts
huh??
you need the correct torsion springs
or they need adjusted or replaced
Pro talked me into it,
When I built our shop I used a 9' tall by 18' wide insulated overhead garage door, a glue-lam header beam, and a 10' high ceiling height for the entire shop. The entire outside walls were wrapped in Tyvek and 10" of ceiling insulation. I also used Pella windows. It stays cool on a hot summer day and is really toasty all winter even when it is windy and below zero outside. I also installed a bathroom and a separate electrical service. The outside roof has a complete ridge vent with adequate soffit ventilation.
Yes, I built houses for a living for a few years before carpet cleaning.
nothing wrong with that, as long as he didn't feed you the line of bullsh!t the door was "too heavy" for a "normal" opener
Changed my mind again. Im sticking with what has been working. Going for another Chevy 3500. Thats final. Any of them will fit in garage for service. Makes no sense to change. Thanks again to y'all for giving me the facts. Glad I'm not rushing this. As long as the Everest can fit in it. Do you know it that's possible?Thanks Papa John, its not an issue now because it makes sense to keep my 2016 inside, especially winter, and the new Truck will be in driveway with no limits. I just got a new door opener. No track it just mounts to the side of the bar on the wall. thing is sweet.
Sounds like what I did with my new garage. 2 x 6 construction with R-19 insulation. Instead of drywall on the walls, I used 1/2 sheathing. It's very durable and yo can hang stuff off it without having to find a stud! I only went with 8 foot doors though.When I built our shop I used a 9' tall by 18' wide insulated overhead garage door, a glue-lam header beam, and a 10' high ceiling height for the entire shop. The entire outside walls were wrapped in Tyvek and 10" of ceiling insulation. I also used Pella windows. It stays cool on a hot summer day and is really toasty all winter even when it is windy and below zero outside. I also installed a bathroom and a separate electrical service. The outside roof has a complete ridge vent with adequate soffit ventilation.
Most municipalities will not allow a floor drain in a garage in new construction.Floor drains?
