Oct 5, 2009 #1 daniel@procarpet Member Joined Sep 7, 2008 Messages 3,797 I need to get this hole glide on my 4 jet prochem wand asap. I have heated it and now what should I do? What is the best way to get the glide on?
Oct 5, 2009 #2 J joe harper Member Joined Oct 21, 2008 Messages 4,992 Location florida Name joe harper Dan, the quad wand is the HARDEST to get on.... SUPERHEAT it ...you won't hurt it....Then force one corner on...& work it to the other end. Wear some gloves....It is a really tight fit....
Oct 5, 2009 #3 daniel@procarpet Member Joined Sep 7, 2008 Messages 3,797 Rubber hammer mallett. Yes or no?
Oct 5, 2009 #4 J joe harper Member Joined Oct 21, 2008 Messages 4,992 Location florida Name joe harper NO... Put it back in the boiling water.....YOU cant over heat it....I will return to its shape And conform to the wand....Don't worry..I know it is a lot of money...but you won't hurt it.
Oct 5, 2009 #5 Jeremy Member Joined Oct 9, 2006 Messages 3,720 Location Indiana Name Jeremy Whittle it down a bit at the corner.
Oct 5, 2009 #6 daniel@procarpet Member Joined Sep 7, 2008 Messages 3,797 Well I got it on. It was like giving birth. No I can't imagine that. :shock: I popped one corner on and then used the rubber mallet to tap it on.
Oct 5, 2009 #7 J joe harper Member Joined Oct 21, 2008 Messages 4,992 Location florida Name joe harper 10-4....!!!!!!!!!!
Oct 5, 2009 #8 Ron Werner Member Joined Nov 25, 2006 Messages 8,726 Location Sooke BC, Lower Vancouver Island Name Ron Werner if it doesn't fit, force it If it breaks, it was meant to be replaced
Oct 6, 2009 #9 sweendogg Member Joined Jan 15, 2008 Messages 3,534 Location Bloomington, IL 61704 Name David Sweeney ... who needs a pot of boiling water when I have a heat gun!!! :shock: But, you have to wear leather gloves for that puppy.
