Should be OK with the 120 to 130 max that comes out of the tap. I have a 3200 watt heater 15 feet down line from the pump. I've had the Worrier 3 years and it's ate 5 (or 6?) pumptecs, so I can't imagine it being any worse.
Mytee uses this new Cat on the 1003 and 1005 Speedsters. The really big difference is how smooth the pump runs. This is because of instead of using a single shaft osolating by the bearing as on the pumptec, it has two connecting rods attached to the bearing and the pistons. The pump also has a drain at the bottom to easily drain any water in free*ing temps. Mytee using QD's on the ports to attach the hoses. The ports are on the top of the head which makes them easily accessable. I think you will like it Willy. Let us know what you think inconparison to the triplex also.
