Russ T.
- Joined
- Sep 26, 2008
- Messages
- 3,556
- Name
- Russ Terhaar
Do you guys prefer the slotted, or hybrid type with slots and small holes?
I clean such a mix of high end residential all the way to grungy slumlord college housing. I rarely pull my vacuum from the van because I work alone. My wife is great at having the residential custies vacuum prior to my arrival but the college kids are very different. I'm running a 20HP Roots blower #45 and moving to a 14 inch Westpak wand with 4 jets and a 1.75" tube. The guy at Westpak said Greenglide makes a great fitting glide for their wands ($140 extra).
Russ Terhaar
The Clean Machine of Iowa LLC
www.thegreatcleanmachine.com
Office 515-494-9494
Cell 515-370-2214
If you can- go with a wand that is 2" tube all the way!!
I ordered a wand with a 1.75" tube that will accept my current 1.5" whip lead inside of it but I'm open to changing to 2" so it's compatable with that too. I started cleaning in '99 and have always used a 1.5" but maybe I don't know what I'm missing? I do work alone but am only 37 and not afraid of a little work. I also ordered a green glide (hybrid slots) to go on it. The only glide I've ever used sits in my truck all the time because it didn't fit my wand right. Anyway... I've been doing things "my way" long enough that I'm feeling the need to get on here more and mix it up with some guys who are also pros who take their craft seriously. I have much to learn and appreciate the advice.
Russ Terhaar
Office 515-494-9494
Cell 515-370-2214
Get rid of the whip....pointless. Go with 2"vac hose all the way to the wand. Even if you keep your skinny tube wand you can still connect the 2" hose by changing out the cuff.
Russ I like the Slot and then the Hybrid. Use the Westpak and also the 1.5 with 2in vac straight to the wand. You may find that its good to carry both Wands on the Truck.
I always have 2 wands, if a break happens just go another wand. Keep the whip hose around and use it when Dry times are not that critical. You will feel a little muscle worked from the 2 inch wand at first.
The reason the 2 inch would be harder on your hands is if you don't have a glide.
My 2 inch wand is 2 lbs lighter then my 1.75 inch wand.
The opening or surface area of a bigger wand say a12 inch compared to 14 inch, the 14 inch is going to be harder to push because it will lock down on the carpet more.
The glide will help with drying and lockdown.
It can also be harder to get your hand around a 2" tube to the valve trigger. You may have only a few finger tips left to trigger the wand leading to chronic conditions. Such as: trigger finger and ligament damage from years of repetitive motion.
I already have some trouble with my fingers. They lock closed sometimes...it makes my wife nauseous
Russ Terhaar
Office 515-494-9494
Cell 515-370-2214
Basically, if you are using anything other than a hole glide, the reason is likely one of ignorance, or substandard cleaning practices.
won't go wrong with the hybrid. Its a good glide configuration. If you want to find out just how well they work, try using the new wand without the glide and then attach it.
The 2" wands are harder on the wrists. Need to design a more wrist neutral handle for these wands.
