Had a Solus 500 for 9 months.....
Willy P
Willy P
John LaBarbera said:
[quote="Willy P":1je9i0cx]Pull the heater. Why the hell they put an internal heater in a machine is beyond me.1000 watts wouldn't heat up a cup of tea. Kleen rite makes a kick ass 3200 watt in line so you can open up the jets a bit for some flow.You cook up your components with that internal shit. Curtis, I'd like to know how often you use those Ninja Warriors. Mine was new last year, works part time and I've done both vacs and pump. POS. The old Recoil keeps on chugging along....
Hi Willy,
Do you think that the heater is the problem or is it the pump circuit board?[/quote:1je9i0cx]
Probably a combination of both. In my experience internal heaters raise the temperature in the motor compartment too much for the limited rise they give. I had a ton of problems with my old Kleenrite heater as the circuit board was always the culprit- too much heat for the components.
