- Joined
- Nov 25, 2006
- Messages
- 8,726
- Name
- Ron Werner
Brian R said:[quote="Ken Snow":1l9x7x6l]joeynbgky said:We do it with one guy. Its called hustlin and working hard , fast and still doing a good job.
Sent from my g2 using tapatalk. Whofat
10-4 good buddy :-)
It's also called not over working a job...Some guys clean the clean carpet even though it's already clean.
That whole vacuuming for an hour (sorry Ron)...Even if you're OPing....is ...How did John Wayne put it "reGoddamndiculous)
Just clean it and get done.
But then if you're charging double or triple I think some guys think they need to justify that price with "time spent"....and maybe so...But it's all about how much money you can make in a day (in this example) If you make double on the job and spend triple the time or worse....no good.[/quote:1l9x7x6l]
2 guys is definitely more enjoyable working, esp if both know what they're doing.
And these "vacuuming for an hour " comments are so far out of context its getting silly. Vac what needs to be vac'd, and take the time needed, but don't just run an vacuum over it and say "Its vacuumed", any homeowner can and does do that every day and they leave a ton of stuff behind.
"Justify", yeah, we have to explain that the last cleaner only surface cleaned (whether by HWE or HOST or Bonnet/OP) and there's usually a ton of crap still in they're carpet. Thats why they are sneezing still and having runny noses.
Do realize what kind of crap can come out of a sofa??!! Sofa arms hold a lot of fine dust. To clean one in 10-20minutes, may was well take the carpet wand, spray it down, then dry it with the uph tool.
You can watch vid after vid of hustle cleaning on youtube, doing a decent job, enough that the homeowner would look at it and say its cleaner than when they arrived. Great busn model for making money, but is it part of the problem or part of the solution? Its no wonder we have to deal with crap like the SOA and its a bugger trying to charge a decent price for doing the job right.
I watch threads like this, see all the money being made and wonder what the hell am I doing wrong. Then I go clean Mrs Jones who just had her carpets cleaned by some guy that was in and out in less than an hour. I pull a canister of soil which takes me 35min, set up and clean it properly, takes me another 45min, all in all at least 2hrs with moving furn, sucking up foam, etc, basically fixing mistakes and mediocre workmanship.
