rwcarpet
Since there are no Powerclean techs available, maybe some of the mechanics here can chime in. It is a Ford Endura, carbureted, 4-cyl. 2003. Very hard to start when cold...sitting all night, assumes ambient temp. Choked , not choked, wide open throttle....nothing starts it. But give it a shot of starting fluid, and it cranks right up and runs fine. It also starts through out the day as long as it's warm.
Good filters, just changed the plugs. No difference. When it does start, it runs strong.
It has a distriborless coil ignition system, which fires 2 cyl's at the same time....one on combustion, the opposite cyl. on the exhaust stroke. I've got extra parts from the used genesis I bought, and will start changing parts out.
Where should I start? You think the cooling temp sensor or the egr valve is the culprit??
