daniel@procarpet
- Joined
- Sep 7, 2008
- Messages
- 3,797
I have to clean about 1500 sq ft of hardwood tomorrow. The floor is in good shape and has a finish on it.
I am going to use a neutral wood floor cleaner and white pad to scrub with.
Can I use my sx-12 to rinse the solution at say 500 psi, or should I buy a squeegee attachment for the gecko?
The squeegee tool works good and picks the water up good, but you can only pull it backwards. Impossible to go forwards.
If the sx works, then that is what I want to use. I don't want to leave the floor too wet. The sx should pick the water up just fine especially at lower pressure and fans going.
