steamwizards
Okay so what Ive learned is that you should use cold water in your tank instead of hot water, correct? Well how long should the element take to heat the water up and is it best just to upgrade the element so it doesn't take as long to heat up? And what wattage element would you recommend?
Thanks
Rob
Thanks
Rob
