Trip Moses
IMOL
- Joined
- Sep 19, 2018
- Messages
- 3,624
- Name
- Trip Moses
I’ve used this one for 2 plus years. It doesn’t have a pressure switch. It runs tthe whole time the TM is running. It may have an internal switch, IDK. Works great.
That makes me feel better. That's the exact same as mineI’ve used this one for 2 plus years. It doesn’t have a pressure switch. It runs tthe whole time the TM is running. It may have an internal switch, IDK. Works great.
I don't know. What is an on demand pump?Matt is that an on demand pump?
That's a pump with a pressure switchI don't know. What is an on demand pump?
Do I need to install a bypass hose to send the water back to the tank somehow? Because it seems I have a bypass pump. I hope there’s some type of switch I can install to make this setup a Demand pump.Demand pumps turn on and off with a pressure switch,usually attached to the pump.
Bypass pumps trickle a small stream back to the fresh tank and run continuously.
I think that has a pressure switch. It's that little square thing on the end of the pump. The only to tell is to hook it up, put a spring loaded garden spray nozzle on the end and turn it on. When you spray, the pump should turn on. When you let go, the pump should turn off.Do I need to install a bypass hose to send the water back to the tank somehow? Because it seems I have a bypass pump. I hope there’s some type of switch I can install to make this setup a Demand pump.
Not all bypass pumps go back to the tank.Demand pumps turn on and off with a pressure switch,usually attached to the pump.
Seems better than the harbor freight motor I installed in my van.![]()
High-Flo High Performance 2.4 GPM BYPASS 5151089 12 V "NEW" | eBay
Find many great new & used options and get the best deals for High-Flo High Performance 2.4 GPM BYPASS 5151089 12 V "NEW" at the best online prices at eBay! Free shipping for many products!www.ebay.com
I used these for 20 years with the same tank.
Plumbed straight from the fresh water tank to the mix tank with no inline filter.
All I ever used was a inline filter screen on the garden hose when filling my tank.
Usually small portable machine centrifugal pumps.Not all bypass pumps go back to the tank.
I used internal bypass pumps for years.
