Help me shop
Meter Maid
The Undetective
The other consideration is having a belly tank for freshwater. I have a standard roof transit, so I can only fit the 570 in there without a belly tank.
I can get a belly tank in there with a 370.
I typically connect to customer water, but with lots of snow on the ground here in Ohio, I like to keep water on board.
In a cold weather climate a fresh water tank is beyond convenience. You need one, it saves time, blame for using their broken water pipe too.
Naww, it's the recovery. 230 waste water is awesome
thought they had a large fresh tank as well. Just looking at their website. 110 gallon standard and 200 gallon optional. Apparantly the 200 gallon is only installed in box trucks.
this your first winter with a TM?
many outside hose bibs will be turned off from inside
get a garden hose faucet adapter
this one
has inside and outside threads and will fit 99.288% of res faucets and 92.773% of com
But washer and dryer hookups are fair game
and have extra rubber washers, cause once you remove that hose, you own it...
learn how to tighten a hose bib packing nut too.
cause all those valves you'll encounter ain't in great condition
One more thing..
always kink your garden hose after you hooked up (inside or out)
it assures connection and packing nut is drip free and the biggie, lets you know if the outside hose bib froze and broke over the winter.
If no back pressure on the kink'd hose, the water is pouring in the bandbox and down the basement walls.....
One more thing..
Great tips, yep I give away many flat washers throughout the year...
KevinD
Kevin Dumas
One more thing..
Been there done that. Nothing like performing a water damage job "For FREE" after your regular scheduled job.
