Help QUICK! Hydroforce question
joeynbgky
Joey
Don't laugh............
I usually use a hydroforce revolutioin, I have a regular HF that I am going to try out... I got a package of colorfull metering tips........ where the heck do they go? I tried to tape it on the end with duct tape, it didnt hold.. J/k but really where do they go?
I believe above the draw tube that goings into the jug. I don't know off hand what the different colors tips ratios are.
joeynbgky
Joey
I have a package that has all the colors and the ratios im good on that, i just dont know where to put the thing.. The HF hose is split i can see metal but im sure it will work fine.
You need to fix the hose so it goes all the way to the bottom. The tips screws in I believe. I believe without the tip is 4:1. Most guys run it that way, because the tips get clogged easily.
Erik
Erik
I like Nate's pics. Full throttle shiteatinggrin
yellow tip is 8:1, I have one sprayer at 4:1, no tip, and one with yellow
