help
Albuquerque
Ron lippold
I think I have a bad diaphram in my chem pump Please help I could use a break down if one is avaliable.
thanks
C
Chris Sheldon
Ron, I see you are in ABQ. A&R Supply has those diaphragms in stock.
ACE
Lawrence, KS
Mike Hughes
I’m not what sure about the V’s but, most chemical pumps don’t do well at high PSI. I put a high quality ball valve in front of the chemical pump so I can turn it off when I do T & G. Before that I was doing lots of rebuilds.
Arizona
did you look at the check valves..........
