Mine is the 03 with the vacuum advance speed control (probably the last year they used that system). I was monkeying around with increasing the engine RPMs to 1900 and even 2000 from the factory 1500 which you can do by turning the nut on the vacuum advance, and also the vacuum lift to 19" and 20" by tightening the vacuun relief on the waste tank. That sucker was screaming. But then after a few days, on a job it started making wierd sounds and the vacuum dropped to nothing. It was the vac belts slipping. They were boiling hot. Freaked me out so I reset everything to factory settings.
WM made a Pro1200 hi lift model that was even more heavy duty and had a water cooler system for the blower that did operate at 20" of lift and that could easily dual wand.
