I just bought a ThermalWave and want to know what you run your lift at? They set it at 12 at JonDon.
Set it at 11 the first day that I got it with no problems for over 2 years...saves on my fuel and everything else...
got the 570 and set it the same way....why would I want to run it any higher then that if I don't need to...???
you live in a warmer dry climate
I ran mine at 14, probably get a little better heat and heat recovery
The blower rep cringed when he saw a low and med. setting on the machine. He claimed that it would last much longer if ran at 80% -90% of max.
As a total mechanical ignoramus I am curious.
I have a diesel Apex and it is set at 13, yet the gas Apex is set at 14.
At the shop they told me that trying to increase the water lift will damage the machine.
Why the difference between gas and diesel?
Why would it damage the machine if increased?
Why the hell would you only be getting a maximum of 13" hg from a modern TM ???
That is ridiculously low for a high performance machine.
What kind of misguided engineers would offer that ??
Larry
P.S. The factory blower engineers like high RPM's for better cooling.
Living in Hell or other words AZ. can help any cleaner dry carpet fast. I couldn't believe how fast the carpets dry with little effort in AZ. Every blower manufacture that came to Blueline told me blowers are built to run hard. A blower will last much longer if its ran hard all day than if its under driven. The blower rep cringed when he saw a low and med. setting on the machine. He claimed that it would last much longer if ran at 80% -90% of max.
To all guys living other than Outer Darkness setting your machine at 14 is the best. IMO
Just a little jab to the AZ. guys. Many people like it there. I just thought it was the worst place on earth. To each his own. i know people that hate Idaho so home is what you make it i guess.
people will believe anything they are told if they don't know any better....
So if you know more than the guys that engineered the blowers and have delt with 1000s of them over the years.....please enlighten us.
I just told you what they said.
