John LaBarbera said:randy said:[quote="Art Kelley":19e7j64p]For a portable I think DevilThomas had the best idea: get a rotovac CFX pod and a pump from Terry. Here's what Thomas said aboit it:Rotovac stuff is kind of Pricey....look for lightly used Rotovac equipment on ebay and craigslist...you can save thousands of dollars.
I got my used 360 with carpet and carpet brush head for $1300...28 lbs
I got my new duel cord CFX power pod from Rotovac for $1733...40 lbs...
If blowing breakers is a problem you can go with single cord CFX ...but it only sucks about half as hard as duel cord.
Best places to plug in extractor... washer plugin, kitchen plugin, bathroom plugin. You can plugin power wands in any room you are working...they only draw about 5 amps.
Rotovac original ...cleans great...but very slow.
Rotovac 360....cleans good... much faster than original.
Both power wands tend to be super soakers...adjust water flow and make "dry" passes.
Get a 175 rotary, or OP machine and scrub your prespray in...your carpet will be beautiful...
Ok...last thing...get or make a toolbox sized demand pump...6 lbs... like this
This one puts out 170 psi...approx..$300
I'm thinking that a guy could skip the CFX power pod and go with the Mytee air hog instead. You would have better filtration and save $1,000. Also the CFX is sold with the primus of just hooking the rotovac 360 up to the faucet like a steamin demon so why would you really need the pump box if you have decent water pressure in your area to feed the 360 ?
Maybe I'm missing something but the Airhog seems like a far superior unit than the CFX and $1,700 is a bunch of money for a vac box and pump out.
Comments and suggestions please .
Mytee is working on a dual three stage vac Air Hog. The current one is a single three stage 144"/115 cfm. Our Water Hog is a tri-plex General pump with adjustable 50-1000 psi. 2-2 gpm. Very quiet operation.[/quote:19e7j64p]
Any update on the Willybeest John?
