How are you dry vacuuming upholstery?
With your TM hose and Rug Rat?
Crevice tool or brush fitting on the end of your Dyson or Shark?
Not?
I've done it all and am always looking for something better, especially for pet hair.
Currently I'm really liking this gadget...Great but gentle agitation and really pulls fine dust and dander out.
No idea how long it will last but it's cheap enough online to buy twice a year if need be.
http://www.royalvacuums.com/select-...ums/research-by-product-type/handheld-vacuums
The pleated filter needs cleaning after most jobs. A good opportunity to show the client your nerdiness...
Charlie Lyman
Charlie Lyman
My Dyson has a brush attachment that spins with the vacuum. It doesn't remove the pet hair as much as I would like, but it works.
Askal
Al
Backpack vac light soil. Tm on low with dust downer for heavy soil.
Miele Venus cannister. The upholstery tool has 2 fabric strips that picks up hair and lint fantastical
Chris A
I generally just vac out the crumbs but if it's real bad JR will hit it with the regular vac hand tool
Steve Lawrence
Use the TM suction on low speed, of course, with 1.25"vac hose with old fashioned Kirby rectangular brush tools.
Reactions: Askal
Scott S.
Scott
i thought everyone was doing it the kirby way. just a white rag over the suction hole, showing the customer that the upholstery is filthy.
Did one today with the little short hairs stuck in the fabric. Was wishing I had the spinning attachment from my shark. I use a rubber brush that grabs the hair pretty well. The problem with the short haired dogs is some stick straight back in. Nothing worse than a black sofa with white hair.
I use the shark, usually with the rotating brush.
If they still have the offending pet I never promise 100% removal of hair, just that it's now CLEAN hair.
Reactions: Mike Pailliotet
ronbeatty
Ron Beatty
Not?
This is what I use, has always works great.
encapman
Rick Gelinas
Try this: We have 2 cats at home; and I've discovered this gets the hair off a loveseat and chair that would otherwise grip the hair tenaciously, better than vacuuming alone, or anything else I've tried.
1. Cut a FiberPlus pad into small sections. I usually make them into about 4" sections.
2. Gently brush over the upholstery with the FiberPlus pad. Mounds of hair are removed.
3. Vacuum up the hair with an open vacuum hose. I use the Hoover PortaPower vac around the house.
Try the pad trick. It works great for hair removal!
Scott S.
Scott
for thick hair i just wet my gloves and wipe them dry and rub my hands all over and it removes a ton of hair, Then i use a rotarty brush attachment.
Todd
I use the Proteam Backpak or Riccar Radiance with attachments. I don't buy cheap vacuums. I have 4-5 of those in the garage broken down already
Are the sharks really that good ? Costco has them on sale often for a great price.
