How do these hoses rate?
I've never used that brand but it looks and sounds like Goodyear Neptune 3000.
Ed Valentine
Ed Valentine
Goodyear Neptune is what we promote. Great hose!
Best;
Ed Valentine
cross-american corp.
:eekk: Its great hose....up until black death. Alibi portables may not have that issue
Hot tm's will eventually wear a weak spot near the QD. When she pops she will spew hot molten black lava all over walls, ceilings and you clients furnishings. "Great Hose" NOT for most TM's.
Don336
DJ Settle
What hose would you say is the best given budget and safety? My tm gets pretty hot.
Don336
DJ Settle
Ed,
I noticed you have 12'' wand glides for sale on your site. Which model wands do they fit?
The Good Year is fine as long at you keep and eye on it and or replace it as it wears or cut a couple of feet off the end when you first notice wear.
The constant bending just below the press is where it develops a weak spot. The water gets in behind the braided wire then you get rust and rubber cooking. Its a mess.
Ed Valentine
Ed Valentine
Don;
The glide fits: #10-0762
Rico;
You are correct in stating that a certain amount of "visual" maintenance/attention must be done when using---any---pressure hose only because of the nature of it and the Operators potential liability.
I understand what you are referring to in regards to the heat factor and what it does to the interior of hoses; however, many of our Operators using the JAGUAR 6.6, or 8.4 models will operate them off the truck and further use a propane heater to heat their water supply on the outlet. Fortunately, we have not heard of the problem you were honestly referring to. having stated that however, I believe that the Operator has to realize how long they can "push" (their luck) any product, again, as important as psi hose is to their operation. I do suppose there is more expensive hoses out there if the operator is willing to pay for it.
Thanks to all;
Ed Valentine
John Olson
John Olson
If you burn someone's kid because you went cheap it is going to cost you more then just money, if you burn the wrong kid, say mine, it might cost you more then you could bare..(bonus points to where that line comes from)
John Olson
John Olson
Its not necessarily in the room you need to worry about. Your usually the one that gets burned in there. It is the one in the living room or the one on the side walk the kids are playing hopscotch over
John Olson
John Olson
Its a real pet peeve of mine. Old/cheap hose. I'll post a picture after I have my buddy send it to me of how bad it can be]
Reactions: Art Kelley
It can get bad. I've lost clients over it, been made to look very foolish and had to buy items damaged by black death.
We've also had to clean upholstery & area rugs for free and washed walls as well as paint a room.
We quit using it for years when it had sprayed a new (to us) clients freshly painted walls.
She asked "if you know this can happen why would you use that type of hose?" My response was one of the dumbest I ever said "Because its flexible and the technicians like using it". We never worked for her again. :errf:
We've used lots of others since but are back with it and just keep a very close eye on it and toss it at fist signs of wear. :neutral:
Reactions: Total_Rookie
John Olson
John Olson
600 hours or once a year for your main 150-200' for good year. you can safely double that for parker closer to 1500 hours but parker doesn't explode but the ends can come off if your running hight temp machines like Steam Way's or 4ht heaters. Most HX machines don't actually get as hot as the gauges say.
Spurlington
Spurlino
I hate the braided hose .. I was tired of leaving impressions on poly carpet. I use Par-Flex. What would be nice is to have a hide a hose. This way theres no worries. No carpet burning .. splashing black death etc..
and I dont want to hear interuption of air flow .. cause filters do that .. Right !!
Spurlington
Spurlino
I knew a guy who flipped the hose around changing the fittings to have the water flowing the other way.
Blue Monarch
Dirk Wingrove
Black death scares the heck out of me. Parker is all I use. Snip off a foot on the truck end once a year and it seems to last forever. Way easier to handle when hot also. I can't even imagine trying to grab a goodyear hose when running high heat.
You just have to know how to handle your hot hose is all.
I've never been good when handling that much hose. Someone is always at risk! ;)
Step back son, you don't want to get hurt! ;)
:lol:
It's easy to stop the Black Death from spraying. My lead end has a piece of 3/4" Id clear hose 5' long over it. A hose clamp around the fitting and your good to go. The hose will last longer because now you have a real strain relief and the Black Death just dribbles out the bottom end. I can't be the only one doing it this way.
Gene
Don336
DJ Settle
Where is the best place to purchase the parker hose or similar product?
jcooper
Jerry Cooper
google cobbs carpet supply, get a 100' piece so the quick disconnects are always outside the home.
Letting hose freeze with water inside will cause black death.
Most poly hoses are NOT rated for the temperatures we use.
Johnny
Johnny
Don't know why anybody would use anything but Parflex. Lightweight, extremely tough, insulated (minimal heat tracks), no risk of Black Death. Only prob I've had with heat (240+ atm) is very rare, fine pinprick holes confined to the first 8-10 inches of the machine end of the hose. Easy to cut off and reclamp. My experience is those leaks only occur with newer hose. Once broken in (tempered?), they don't leak.
Reactions: Able 1
