- Joined
- Sep 26, 2008
- Messages
- 3,556
- Name
- Russ Terhaar
It's just a filter, but it's plug 'n play.
I'm about to replace the CAT pump, and I'm not even scared.
That's saying a lot for me.
What took me so long?
Thanks Steve.What's wrong with your Cat pump? How many hours? Just be sure the pump is the problem before replacing it. Pumps last a long time--unloaders, not so much--and can give the mistaken impression the the pump is funky.
(Your filter and fittings look so clean, almost new, so it's making me think your pump isn't that old.)
Just what Steve says, take your unloader apart and check your seals and o rings. The little piston inside might be worn out. If everything looks good, pack it with grease and try again before replacing the pump. If you do replace the pump, have the old one rebuilt as a spare.Thanks Steve.
This is a 15 year old Butler that SAT for 15 years, averaging @ 53 hours of use per year.
It's got 794 original hours on it right now.
Previous owner said it was "ready to clean".
It wasn't.
The solution line and pressure jumps up and down pretty wildly, until pressure is increased to about 600 psi. Pressure smooths out there. BUT I lose chem injection at that point...kinda weird.
I've replaced the chem line that was caked with dried up product, the chem meter and the chem valve.
I drove her up to see Saiger. He helped me install a chem pump rebuild kit, replaced each of the 5 belts, cleaned out and lubed the blower, did a proper descale, and I can't think of what else but we tinkered with it for several hours before he sent me packing with several CASES of chems and a barely used Seal a Door!
The pressure issue is keeping me from being able to clean with it still, however.
I honestly don't know what else to do. If a CAT pump rebuild doesn't do it, I might cry.
I'm either going to send my pump to Butler to have them do it or I can try to get it to Dultmier in Omaha. Both companies seem friendly and eager to help...but they are far away.
This is why I wanted a Butler, honestly. I need to get more comfortable and capable with the equipment I'm running.
My closest supplier is Interlink out of Omaha. I never go there because it's 3 hours away. That's 6 hours both ways and I'm not Marty.
Kansas City is similar distance.
There's a huge hole in central IA, that a good independent supplier could do really well in.
Can anyone think of anything to check before I pull the pump out?
I'll send it out to Butler or get it to Omaha this week.
I know it's going to be great once I get this thing smoothed out.
We didn't take the pump apart. I pressed him a little for time, because I didn't get there until after noon.Did Saiger take pump head off to inspect the high pressure seals and plungers?
Those damn plungers cost more than a house in Iowa.
I feel like I've spent enough time here, I should know what DAT means...Ignore all these idiots and carry on as if you hadn't posted this DAT
DAPDumb a$$ thread. It's a Marty thing.
DA Post
http://mikeysboard.com/threads/bulletin-board-acronyms.278060/I feel like I've spent enough time here, I should know what DAT means...
Thanks Brad.Try the pressure washer shop first.
Drive the truck over with pump installed.
They may want to bypass unloader for flow check.
Unloader is around $100 and easy swap too. The shop if it's worth anything will have a unloader on the shelf.
I use a local pressure washer shop and several other cleaners.
Allen wrench will get the block off to check plunger condition.
Just don't force it back on crooked.
Seals and valves are under the big brass nuts
If you have checked all other plumbing issues, I would return the CAT to Butler and have them send newIm somewhat mechanically inclined, but I'd just buy new to know it's new... Then you have a back-up or other to test... Just get the TM up and running, the fook around with it later when you have time...
They will credit you the rebuild cost of the one you return
I've done it , it's not cheap but like Nate said , you'll be good to go
They last a long time especially under proper use and care
This guy clearly neglected his equipment
You got an awesome deal... of it cost you a couple grand to get in top condition so what?
