daniel@procarpet
- Joined
- Sep 7, 2008
- Messages
- 3,797
Able 1 said:YOU are probably better off going to the supplier.. The front heat exchanger is BRASS!! At what point did you say f-it I'll just pull as hard as I can instead of cutting the hose off :roll: ?At least the front one is the cheapest..
That is about what happened. The hose has already been cut once. The key to getting it off is to wrench the fitting off, but then it needs to be sweated back on. So really I should not be messing with it.
Yes it was the brass one so about 275 or so to replace.
Lucky for me they had one in stock.
