How long do you leave prespray in you inline sprayer?
Johnny
Cleaning Professional
Johnny
How long will you leave prespray in your inline sprayer before dumping it? I usually dump it at the end of the day, but if you have a job the next morning or even the following Monday after a Friday job that requires the same formula, i.e. Extreme and H2O2, will you mix fresh or dump? How long does it take to deteriorate in the jug?
Much obliged.
Reactions: Living The Dream
sassyotto
Paul
I use liquid PS and add powders as boosters as needed, so I carry two extra containers of PS on the truck. So basically I dont throw out PS.
Johnny
Johnny
Seems I've wasted a lot of chems over the years. Mixed fresh prespray and rinse every day.
  • Wow
Reactions: Nomad74
I think if it's sealed in the hydroforce jug it will last as long as you want.
Just shake it when you want to use it.
But if you add something like peroxide then I would refresh it
I've now lost count of how many carpets I've encapped with just water running through the machine and the wet microfiber pad.
I go to refill the jug and my 8-oz cup of super duper pixie juice that's still sitting there from the last supposed fill up...
Living The Dream
Swani
You should be more alert?
Living The Dream
Swani
Much obliged.
Usually I don't have much left especially when using 4:1, but when I do, I just mix up a new batch and add it in for a little boost, unless it's someplace with nice carpet. Then I'll just dump it in the waste tank and mix a new batch to the carpets needs.
Reactions: Johnny
Much obliged.
The soap salesmen sure do respect that you are reliable in keeping your prespray fresher than a loaf of bread in your cabinet.
DAT
Bill Cheryl
Thats why i use way less encap for most of the cleaning. If it says 4 oz per gallon, ill use 1 oz per gallon. It works..
