alazo1
I'm trying to get to the high pressure seals on this pump. The manual says to take out the low pressure then remove the seal case with reverse pliers. The seal case has holes on the side of it. Do I buy reverse pliers to grab the holes and pull out ?
Though this is not the same cat pump, a picture of the same seal case in on page two.
http://www.catpumps.com/products/pdfs/31402A_MAN_1CX.pdf
thanks,
Albert
thanks,
Albert
