How to remove the seal cases on a Cat pump?
Johnny
La-Z-Boy
Johnny
How are the three brass, cylindrical, press-on seal cases removed from a Cat 3CP 1120 manifold?
There is a tool to make removal easier, but what is the hard way?
Much obliged.
mine is a 5cp and i really can't remember how i rebuilt it yes, I really clean up pet shit for a living Dad..
LOL..
but it wasn't hard .
think I pulled the manifold, took it to the bench and just popped out the old seals and put the new ones in.
Don't recall if i had to tap them in or not ...if i did, I probably used a socket of appropriate size
Be sure you observe the orientation of the old seals ...so you don't put the new ones in upside down
Able 1
Wi
Keith
X2 real easy to do if you take your time and see how they are put together.. If you are having trouble getting them out stick a screw driver half way in and pry them out, but be careful to just pry on the piece you are going to remove.
Johnny
La-Z-Boy
Johnny
Got the top seals out but the seal cases need to be pulled to get the seals or packing under them out.
