juniorc82
I put in a bid for a giant hotel which is going to need cleaning on a regular basis . The hotel has several ball rooms and hallways. In addition to the ball rooms and hall ways it has a restraunt which I feel that I put a good bid on. Because the ball rooms are anywhere from 2-7500 sq ft and I will be doing them with a cimex I bid it pretty low at about 13.5-14 cents. I have bid large commercial jobs pretty low when I know I can use the cimex and still made money. I did bid alot higher on the restraunt and guest rooms because I have to hwe with a porty because it is a high rise. Keep in mind in my part of the country commercial carpet cleaning gets bid on lower than most areas. do you think my bid was on track for an account that will have work every month if not every 2 weeks? how would you guys have bid it? ( by the way i am friends with the mgr so I got it for sure , all I had to due was undercut the existing company by enough to be justifiable in switching companys)
