The pump puts out 3.5 GPM the primary orifice when new is the equivalent of a #2 jet, at that pressure it will flow .7 GPM; the recommended tool for that machine should be jetted equivalent to #4 and should flow 1.4 GPM. Check these two items and most times you find the problem; the primary orifice may not be properly seated or it could be worn, I have seen it accidentally get swapped with the secondary orifice which is the equivalent of a #6 jet which at the stated pressure will flow 2.1 GPM. Marcus Van Wyck
Lead Technical Service Representative HydraMaster/US Products Pro | Customer Care | 11015 47th Ave W. | Mukilteo | WA | 98275 | Customer Care: 800-426.1301 ext. 1633 | Fax: 425-771-7156 www.hydramaster.com | www.usproductspro.com
