After seeing so much debate about the accuracy of hydroforce adjustable sprayers I decided to actually test mine. I tested after a rebuild kit by measuring the amount of solution put into the jug and the total amount made once the jug was empty. I did this on two different occasions weeks apart to make sure the numbers were accurate.
These are some real accuracy numbers from my hydroforce revolution.
The testing was done at 500 psi, 245 - 235 atm, 225 - 215 atw, using a live reel with 275' of 1/4" parker parflex solution hose.
DIAL - ACTUAL
4:1 - 4.5:1
6:1 - 4.75:1
8:1 - 5:1
12:1 - 5.25:1
16:1 - 6:1
24:1 - 8:1
32:1 - 11:1
64:1 - 14:1
Just thought some of you might find this interesting. I have now labeled my hydroforce with the correct numbers so I will know when using it.
DIAL - ACTUAL
4:1 - 4.5:1
6:1 - 4.75:1
8:1 - 5:1
12:1 - 5.25:1
16:1 - 6:1
24:1 - 8:1
32:1 - 11:1
64:1 - 14:1
