I got the hydro force blues
C
Curtis Pennington
I love my HF..yellow tip...nudin better, plenty of pressure to lay it down thick if needed,slouiton line already dropped ready to go after spraying. No battery changes, no heavy weight to carry, no clogged tips,barely enough pressure on the nasties...need I say more?
joey895
Joey J.
I love mine too. I've got a hydro-force and a spraymaster and never any problems with either. I run mine with no tip. I confess though I did let the bb hype get me to using a battery sprayer for close to a year until it started not charging well (that turned out to be due to a loose connection on the van not the sprayer), in the mean time I started using the in-line again ,man what a time saver, and let's just say the battery sprayer is regulated back to protector and high rises only.
floorguy
Doug
sooo what your saying is i need to try it again??
ok ill do a bucket test and see where i am at
Amendment. I used my yellow tip today, can't tell you what temp I was running as I was on the 3rd floor, but it got hot enough it stopped sucking soln.
So I let the line cool while I groomed where I presprayed. Then sprayed some more.
I'll be turning it down when I first start it now.
T
Like Joey my omni is on the fritz right now. So I bought an inline from jon-don while I was in tampa for a FCT class. A power force II, it came with two 5 quart tanks. 2 tootsie rolls, an 04 tip for some reason that I don't understand. And the regular fixings I suppose. I'm going to try it out in a little while on my first job. I had been fighting my revolution hydrojunk on monday and tuesday.
damn shame youinz bought that POS Omni
They dropped the ball when they discontinued their 3gal electric and came up with that abortion they call the Omni
All their original design needed was a couple mods, like vertical gunjet holder, a rocker switch instead of that "begs to get broke off" toggle and the thing would be as perfect as an electric gets.
...L.T.A.
Funny you should say that.
I've rigged mine with a rocker switch. Took some surgery to make it fit but works just fine.
The biggest thing that gets in the way is all the coiled hose.
A
alazo1
I'm back to the hydroforce now. I think the others(pumpup and hudson) don't like powder. Right after I took the hudson's pump apart to check for obstructions, it hasn't been the same. Output is much less. The cover of the pump keeps pinching a piece of the rubber.
Cometo think of it spayers have always been a pita for me.
Albert
A
Able 1
Tested mine today and it's running at 8 to 1.
I did notice that my rinse went down 1/2 gallon when running off, :shock: pulled the injection apart and the diaphram was ripped, I had a spare so I'm back in action.
Lyman
Lyman
I am working on a stainless yellow tip. My local machine shop is very slow on projects.
