- Joined
- Oct 22, 2012
- Messages
- 28,243
- Name
- Ron Marriott
I have several extra hydro-force jugs. On big jobs, I just swap out a new jug. I use 4-1 ratio. Rarely have any problems.
This is all I need in life.
They look like a 5, but she's a perfect 10. I wonder if she likes Wendy's.Are those jugs five or seven quart?
It does. That's the reason your jug lasts longerSo a 4 flow spray tip isn't choking down the spray too?
She's got the last name....I wonder if she likes Wendy's.
No it doesn't. It just sprays less of the proper dilution.So a 4 flow spray tip isn't choking down the spray too?
I've been doing the same thing you have for several years.Well I’m no X Purt but we currently have 6 HF sprayers ( 2 in each van)
I’ve owned easily 50 over the years and since 2002 when we bought our first Butler , I take the yellow tip out
Max dilution helps add more chemical in tough areas without flooding the carpet
You can easily refill by carrying a 1-2 lb container of powdered pre spray and mix it in the jug with the wand
Instant heat and mix
If you think your prespray is too heavy, add more water as the jug empties
You mathletes are over thinking this
Over 20 years?why so many?
set it at 6flow jet
I missed that part.
, but why not just go 8:1 on commercial?
Thats why I've been talking about itI missed that part.
IDK mine is That high. I believe it's a 4. I'll have to check when I return to work.
Why am I wanting a Burgman?
It was impressive for what it was.They got rid of the 650
I've wanted one for a while
most pull 'em and go naked because they're even more unreliable with the 8-1 tip
Isn’t that only with powders? Liquids flow better.. Some powders were sh!t to put in a HF.. I like the 7qt wide bottom HF 4:1.. I use Bio Break for powder and Zone Perfect for liquid..
Sticking the wand into the jug help to mix the product while refilling it.. Seen Lockhart do that at a MF..
Nope. The term "soap" as you call it over the years has been used by "you tube" miracle cleaners and the every vanishing Kirby salesman. So what's your soap of choice "Dawn" ? You know it takes grease out of you way. LOLAre you one of the carpet soap salesmen?
Detergent?
emulsifier?
Or innacurately phrased term “prespray”
Psh..Liquids were the only thing halfazz reliable in the POS.
That's all we used in ours.
and they're still inconsistent with PSI and temp changes.
(PSI ATW is different with a 100ft of sol line compared to 250ft out)
and if you have a TM that will get an "honest" 200 temp ATW, they're useless
(or you run out to turn down the temp and bleed off heat before spraying)
they were mostly a back-up sprayer for us, as we ran 2 man crew on all res and all "full" days .
and it's plumb lunacy w/two man crew to stop the wand to pre-spray when lectro sprayers are far superior, precisely dilute/mix consistent and just plain more reliable.
Anytime I say “soap” is through sarcasm only.Nope. The term "soap" as you call it over the years has been used by "you tube" miracle cleaners and the every vanishing Kirby salesman. So what's your soap of choice "Dawn" ? You know it takes grease out of you way. LOL
Usually clogs because of trying to mix powders right in the jug. Most powders, especially those that contain oxidizers need a thorough stir with a stir stick before pouring into a hydro-force. I mix mine in a pail and only when it's thoroughly dissolved, do I pour it into the inline sprayer.mine last a long time. I have about 6 empty jugs.Psh..
Operator error.
