I have a dilemma I need help with
Onfire_02_01
Cleaning Professional
Jeremy Gray
A property management company I clean carpets for called me in to a new property they just built. They have installed luxury vinyl planking before fully finishing off the rest of the unit. The construction dust has now become ground into the tiles and they would like me to clean it off. They have mopped several times and it doesn't help. They have a guy currently doing it who for various reasons is making himself a problem. He has been using a 175 and black stripping pads to take the dust out. I have talked with a sales rep and have been told that mopping is all they recommend.
How would you guys go about dealing with the problem.
Mop down a nuetral cleaner with a micromfiber flat mop w/ scrub strips, dweel,then rinse with a hard surface wand at 300 psi and be less of an idiot than the last dude.
Onfire_02_01
Jeremy Gray
I won't be recleaning. Just cleaning the 35 or so that are remaining.
Onfire_02_01
Jeremy Gray
Even at 300psi won't that blast water into the joints and under the planks?
We have done these....the most aggressive agitation we did was with our 10 inch CRB and standard white brushes...
Then went over with hard surface wand extracting....
Came out great actually....
Why did that dude think a black pad was needed? A crb makes more sense to me. Heck, if u don't have a crb, use a soft brush on your 175. It's just dust
Green Clean LLC
We have an old Port-A-Scrub that works nice. Some of the boards have have small gaps that fill with white dust and are hard to get clean.
A black pad will score deeply and has probably damaged the vinyl.
Red is perfectly good for this situation, or (as has been mentioned) a CRB to flick dust out of cracks. Rinse-n-suck is dandy, but polish it off with a microfiber mop. It will look wonderful for 30 minutes or until some penguino tracks dirt all over it.
btw EVERY TRUCK should have a Hard Surface Wand on board.
I prefer the PMF wand as it's a full size S bend and built like a tank.
Some of the others have goofy angles and cheesy hardware.
The new Gekko wand is pretty nice, has a swivel, new manifolds and got rid of the cheesy little connectors and replaced them with proper qc's. Squeegee head for portables/brush head for TM's
Onfire_02_01
Jeremy Gray
I have the 20" brush pro with standard Blue brushes, are those equivalent?
I am not sure if those are considered the standard on that model. I will try to look up and see unless someone else can chime in here that knows first
Those jets look like they're hard to access for any service that needs to be done on them. WAs that just a complicated shadow I'm looking at or is it a tight fit for the socket to remove them?
GreenTechAgain
If you have a laminate cleaning procedure, it should work to clean the construction dust.
These photos are from a job where the vinyl had a texture to it. I hope the previous cleanings with a black pad did not ruin it.
We used only flat mops for extraction. A CRB is the right tool for this type of job.
Slideshow from the whole job:
http://s574.photobucket.com/user/aysvend/slideshow/Trinity_Hearing_Balance
Onfire_02_01
Jeremy Gray
Yep. Looks very similar different color. What did you use for a cleaner? Daily neutral or Bruce?
