rwcarpet
......either the 3 drive plates need to be about 1/2 inch wider, or someone needs to make an 8" pad. It's really tough to clean up against walls and furniture without the main drive plate rubbing on something. If the drivers and/or pads were a little bit bigger than the main drive plate, and could cover just an inch of carpet bigger than the drive plate size, it would make cleaning that much easier around walls and furniture......, and a little cushion to the sides. Maybe I have been using an older model, and the newer ones are bigger, but I haven't used one for comparison.
