gimmeagig
I have been having trouble with my hand pump up sprayers which I've been using for upholstery and also for a high temperature concentrated prespray which I put down in very difficult to clean areas.On both applications I add some Citrus Pro or Groom Solutions Citrus burst to the other chemicals I use.
I own a Hudson and a Hydroforce handsprayer and both have rubber O rings in them. The O rings in both of them started to swell and both sprayers are now no longer working.
I called hydroforce and they told me that the Citrus was the cause. So now I'm worried about my gear.
I regularly add citrus to my prespray in my Hydroforce inline sprayer. Is that sprayer going to fail next? Do I have to worry about that? I don't have a spare on my truck....
The label on the Citrus Burst actually says that the product may damage pumps in extraction equipment.
I have ( in the past) used a little citrus in my rinse. Since then I've learned that that is not a good idea. But today I discovered a leaky water pump manifold gasket in my CDS and now I'm wondering if I might have damaged it by using the citrus.
I was told that it is a good practice to always boost the prespray with Citrus but now I'm wondering......
Are all citrus products the same as far as the potential damage they could cause?
Is there something else that I could use instead or am I overly paranoid now.
