is there a better solvent spotter?
Benton KY USA
No !!
I don't believe that gels penetrate the fiber bundle well enough.
They were only developed for citrus solvents to prevent delamination.
NO, and NO.
Your hair shampoo can often be in a gel form.
Gels have been around for decades, and can be made easily from most solvent bases.
Wi
Keith
DSC'S "Invade" is awesome(expensive).. Larry's stuff is great also.
Dallas, Texas USA
Here is a furniture stain on Facebook that the cleaner tried CTI Pro Solve Gel & other major products on . . .
Only the Dynachem Dye Remover had any effect.
At Facebook Carpet Cleaners Group :
permalink/450594425096107/
Benton KY USA
Adding ammonia will cause many solvents to gel. Then put the mix in a squirt bottle. Some solvents react such with different agents, similar to the emulsification effect that one gets with oil and water in salad dressing.
I've made a gel with magnesium aluminum silicate (a food-grade "clay") to make a product linger in contact longer.
Reactions: GeeeAus
D Luke
MI
Derek
What is gumolene?
Chemiesters Citrus Solvent. For the most part I use it (sparingly) straight as a general solvent spotter. Works great on spots, gum (usually) filtration, etc.
Can also be used as a prespray booster.
Noble Carpet Cleaners
I looked on Bane's site sure enough not for sale in California. I have an old empty wonder how I got it. Also found Solv-a-clean, none dilutable dry clean solution that says do not dispose down a drain. Where the hell would you dispose of it?
Zep Orangel
been using it for over a decade.
it's a good citrus gel. Won't remove furn stains unfortunately but spray some Allsolve into it and you've got your pros choice equivalent.
A gallon costs about $80 but well worth it and it goes a long way.
ryankettering
Oswego, IL
Ryan Kettering
I use hel-gel and also spot-n-boost. I think spot-n-boost is a solvent if I am correct. I don't use that a ton because it's a little pricey. But does well when needed.
GeeeAus
Whyalla
Grant Baverstock
I use Scots Tuff Citrus Boost. Costs me a bit because I import it from over your way to Australia. Normally buy a few cases, each holding 12 Quart bottles. A case is $95USD If I recall correctly.
Works well neat on gum etc.
Mixes without forming an emulsion with water based treatments and is a terrific booster.
To make a thinner spotter I can spray down on larger areas I mix 5oz to a 1 quart sprayer of water. Not much argues with it. The Pro's Choice works so well because it uses Methyl Ethyl Ketone. This is similar to Acetone but has a longer working time.
Acetone and Citrus oil work well 50 - 50 too.
Grant
