Art Kelley said:
[quote="Magic One":3fre0wde]Whats your favorite rotarty machine. 360I, Hoss700 or
RX20
From someone who owns an RX and a 360i and used the Hoss at the
Mikeyfest this year I can tell you that the RX and the Hoss suffer from the same Bloated Pig Syndrome. They both weigh in at close to 100 lbs (or so it seem when you lift those beasts up.) I put the RX away again after testing it against my new 360i for a couple months. At 37 lbs. there is nothing about the 360i that either the Hoss or the
RX20 can do better or faster. It's possible that it's small lightweight motor will burn out sooner, but that is a small price to pay for saving your back lifting a 100 lb. machine. Ask Jim Martin if he can lift the Hoss out of his truck.[/quote:3fre0wde]
My guy can lift it in and out with no problems.....I can't..but the entire reason that I put the lift in the back of the truck for the RX is because I have 4 bad disk in the back of my neck and so I just found away to adjust....I just hook the 700 up to the lift if I pull it in and out....most cleaners don't have the tall box..and the vans are not as high off the ground...carrying the RX or the 700 up stairs is different then lifting to the back of the truck...lifting it straight up and setting it straight down is easier then trying to pitch them almost waist high over the bumper and into the back of the truck.....
