Jim Pemberton is the only one I would trust for this question
How often should I change out the 370 belts?
the rest of you Fidiots suggesting go until you blow, stitching together with paper clips, replacing with bicycle chains or turn them inside out for extra longevity, can just keep yo moufs shut.
I'm probably due myself on the 870. 2400 hours so far. Way better than my Amtex at every 150 hours.
KevinD
Kevin Dumas
I think your manual calls for 1000 hours so that would probably be a good # depending on your tension maintenance schedule.
2000 hours. The belt cooler makes a world of difference on that model.
My service guys tend to be very cautious, but having just interviewed them, they agree.
As Kevin suggested, make sure you check the tension every 100 hours
Andy
Doesn't Matter
check the belts for cracking across the belt. If you keep an eye on them they will give you plenty of warning before they will just snap. For tension, Deflection between the engine and the pump at the greatest distance should be between 1/2 to 3/4 of inch (Just push on it).
Reactions: Mike Pailliotet
jcooper
Jerry Cooper
My belts(370) lasted for at least 4-5 years. Maybe that goofy little frame fan does help.
Even when one finally did go, it just threw some teeth and thankfully it was very uneventful.
Changing them myself the first time was difficult. Would be much quicker now.
